FS This 1963 MGB roadster is very clean and very early MGB. It has an excellent body, no sign of patches or fillers. It has a very good older red repaint as was the original red. It has good chrome and the good wire wheels give it a very goof look. It runs well, the compression test is 145-150 PSI in every cylinder. The oil pressure is70 PSI when warm and no smoke cold or hot. Both carbs seem to be adjusted just right and are very clean as is the engine bay detailing. The interior is OK with the black seats and red piping. Carpets and panels are in fair condition, same as the convertible top and tonneau cover. The gauges and electronics work. It is fitted with an original oil cooler. NEC didn't have to do much to this car other than a thorough over all check. The top has not been up in years but has good top irons. The joy of the first generation of MGB's is hard to describe. In their day105 MPH performance, disc brakes and unibody construction was all pretty advanced. Originally from Scottsville, VA. now resides in Ohio just east of Clevelnd. I could say more about this car but I think I wrote enough. I have a copy of the old VA title and it now has a clean OH title.
Owner: James K.
Price: $6,000.00 US dollars As Is Where is.
Located Perry, Ohio, USA
6000$ == 4800€ !
![Image](https://www2.mgcontact.eu/pictures/albums/userpics/MG1~8.jpg)
Bon OK, faut aller la chercher et la ramener, mais à ce niveau de prix ??????????????????????
It's worth it, Elle le vaut bien.
