Item DescriptionQtyAvailabilityPriceNet PriceTotal Price
Pipe Assembly - Coolant - Stainless Steel PEP102470SS 1 In Stock £72.50 £72.50 £72.50
Clip - Genuine MG Rover YQR100750 6 In Stock £0.90 £0.90 £5.40
Gasket-cylinder head coolant outlet - Genuine MG Rover PET10042 1 In Stock £2.68 £2.68 £2.68
Seal - Thermostat Housing O Ring - Genuine MG Rover CDU3858 2 In Stock £1.50 £1.50 £3.00
Oil Rail - Strengthened - Genuine MG Rover LCN000140L 1 In Stock £63.77 £63.77 £63.77
Kit-bearing ladder liquid gasket replacement - Genuine MG Rover LVV000108EVA 1 In Stock £11.11 £11.11 £11.11
Stud - Genuine MG Rover LYR000021 2 In Stock £1.48 £1.48 £2.96
Seal - Variable Valve Timing Housing - K Series - Genuine MG Rover LJQ100950SLP 2 In Stock £7.48 £7.48 £14.96
Nut - M10 ERR597 2 In Stock £1.33 £1.33 £2.66
Nut FN108046 2 In Stock £0.56 £0.56 £1.12
Fuel Filter- In line - Genuine MG Rover WJN101191 1 In Stock £11.32 £11.32 £11.32
Bolt-flanged head - M14 x 80 - Genuine MG Rover FC114167 2 In Stock £3.56 £3.56 £7.12
Screw - M10 x 30 - Genuine MG Rover FS110301 2 In Stock £1.31 £1.31 £2.62
Sealant - Genuine MG Rover STC4171A 1 In Stock £13.08 £13.08 £13.08
Draper - Camshaft Locking Tool - Rover & Land Rover - K Series 16V Engines 18G1570P 1 In Stock £3.25 £3.25 £3.25
Kit-control valve seal - Genuine MG Rover LXB100070 1 In Stock £28.24 £28.24 £28.24
Seal-variable valve timing hydraulic control unit to camshaft carrier - Service Line Part LJQ100920SLP 1 In Stock £3.17 £3.17 £3.17
Pressure Cap - Expansion Tank - Original - Genuine MG Rover PCD100160 1 In Stock £3.87 £3.87 £3.87
Thermostat - K Series - Petrol - 88 Degrees C - Genuine Land Rover PEL10016 1 In Stock £8.72 £8.72 £8.72
O ring - Genuine MG Rover PYX000100 2 In Stock £0.52 £0.52 £1.04
Screw-pan - M12 x 25, pan head - Genuine MG Rover PYP000200 2 In Stock £1.16 £0.54 £1.08
Rear Camshaft Oil Seal - Red - Genuine MG Rover LUC100220 2 In Stock £4.90 £4.90 £9.80
Front Camshaft Oil Seal - Black - Genuine MG Rover LUC100290 2 In Stock £4.90 £4.90 £9.80
Subtotal:£283.27
Shipping:£14.50
VAT:£59.55
Order Total:£357.32
ce qui fais avec les frais d'envoi environ 418 euros !!!!! + la commande précédente chez O....O 417 euros un total de 835 euros !!!!
me sens plus léger d'un coup !!!!
