Re: Première visite de Tf
Posté : 26 juin 2017, 18:58
En panne sur le retour?
Forum MG automobiles : conseils techniques, sorties et petites annonces sur le plus grand forum dédié aux automobiles MG : MGF et TF, MG6, MGB et tous les modèles MG anciens et modernes. MG Expert
https://www2.mgcontact.eu/phpBB2/
Id_juju a écrit :Elle est à la maison! Il faut vraiment que je lui trouve un abri rapidement !
Album MGSur ce site directement pour plus de visibilité:Check the MOT history of a vehicle
Registration number: PK53MLJ
Vehicle makeMG Vehicle modelTF Date first used14 November 2003 Fuel typePetrol ColourRed
MOT history of this vehicle
Test date13 April 2017 Expiry date5 May 2018 Test ResultPass Odometer reading57,298 miles MOT test number6716 3484 5093
Test date27 April 2016 Expiry date5 May 2017 Test ResultPass Odometer reading57,187 miles MOT test number5725 6104 9256
Test date16 April 2015 Expiry date5 May 2016 Test ResultPass Odometer reading57,007 miles MOT test number7677 3640 5195
Test date28 April 2014 Expiry date5 May 2015 Test ResultPass Odometer reading56,638 miles MOT test number7977 3871 4131 Advisory notice item(s)
Nearside Front Road wheel with a slightly distorted bead rim (4.2.A.1a)
Test date2 May 2013 Expiry date5 May 2014 Test ResultPass Odometer reading55,361 miles MOT test number1480 0272 3104
Test date3 May 2012 Expiry date5 May 2013 Test ResultPass Odometer reading54,371 miles MOT test number2683 4452 2110
Test date3 May 2011 Expiry date5 May 2012 Test ResultPass Odometer reading52,863 miles MOT test number5785 1322 1161 Advisory notice item(s)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Brakes imbalanced requirements only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.5b)
rear brake discs and offside front brake disc rusty
front tyres starting to perrish
nearside rear brake showing signs of binding but not binding at time of test
Test date6 May 2010 Expiry date5 May 2011 Test ResultPass Odometer reading50,388 miles MOT test number6022 9692 0136 Advisory notice item(s)
Rear brake disc slightly pitted (3.5.1h)
Test date24 December 2008 Expiry date23 December 2009 Test ResultPass Odometer reading36,900 miles MOT test number6418 4975 8363 Advisory notice item(s)
Windscreen has damage to an area less than a 10mm circle within zone 'A' (8.3.1a)
Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
Test date23 December 2008 Test ResultFail Odometer reading36,895 miles MOT test number7845 2845 8379 Reason(s) for failure
Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Offside front tyre is cracked in tread blocks.
Nearside front tyre has slight cracking in tread.
All four brake discs are worn.
Test date21 December 2007 Expiry date20 December 2008 Test ResultPass Odometer reading18,762 miles MOT test number3944 4535 7385 Advisory notice item(s)
Nail in offside rear tyre
Test date21 December 2007 Test ResultFail Odometer reading18,762 miles MOT test number1315 3525 7345 Reason(s) for failure
Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Test date21 December 2006 Expiry date20 December 2007 Test ResultPass Odometer reading9,003 miles MOT test number5238 1505 6397
