PIPER CAMS KIT 190CV VERY HIGH POWER DERIVATE SOLID
A VENDRE :
UN KIT ARBRES A CAMES VHPD COMPETITON " PIPER CAMS PERFORMANCE " 190CV
ARBRE ADMISSION ET ECHAPPEMENT (GRAVER) POUR MOTEUR K SERIES 1.4l/ 1.6l / 1.8L 16V
REF: LGC10226 X2
PIPER VHPD POUR " Very High Power Dérivate " .
( MOTEUR K SERIES ROVER MG DEVELOPPER EN PUISSANCE PAR POWERTRAIN UK)
---> ARBRES ADMI ET ECHAPP 280° DURATION 10.3mm LIFT <---
ARBRES A CAMES MODEL AVEC EMBOUT TETE ALLUMEUR
EXTRA PUISSANCE POUR VOTRE PREPARATION MOTEUR
SE MONTE SUR MOTEUR NON VVC MAIS AUSSI SUR VVC !
DANS LE CAS D'UN MONTAGE SUR MOTEUR VVC CES CAMES SUPPRIME
LE SYSTEME VVC ET PERMETTE DE PASSER EN CAMES "SOLID"
(LE CAS D'UNE TRANSFORMATION VVC EN SOLID CAM DEMANDE DES MODIFS MOTEUR ALLUMAGE .. ETC)
!!!!!!!! ATTENTION !!!!!!!!! ----> VU LA PUISSANCE APPORTER PAR CES ARBRES LE MONTAGE REQUIERT LA SUPPRESSION
DE VOS POUSSOIRS "HYDRAULIQUE" POUR DES POUSSOIRS "SOLID" SI VOTRE K SERIES N'EN AI PAS DEJA EQUIPER
CAR LA LIMITE RUPTEUR MONTE A + DE 8000TR/M DONC LES POUSSOIRS HYDRAU NE TIENDRONT PAS LE COUP !
IL SE MONTE SANS AUCUNE MODIF SUR LES MODEL SUIVANT :
( CES MODEL K SERIES ON DEJA DES POUSSOIRS SOLID MONTER D'ORIGINE )
LOTUS S1 Exige , 340R and Elise Sport 190 VHPD
ET CERTAINES CATERHAM VHPD
---> POUR LES AUTRES VEHICULES COMME :
MG ZR ZS MGZR TF MGF TROPHY ROVER VVC 145 / 160 CV 200 BRM VI 400 VVC ET NON VVC
25 GTI / LOTUS / CATERHAM / FREELANDER ETC ....
MONTAGE AVEC MODIF PAPILLON + GROS / POUSSOIRS SOLID /
ET AUTRES MODIFS POUR OBTENIR UN VHPD
SE MONTE DONC SUR TOUT MOTEUR K SERIES 1.8L POUR UNE FANTASTIQUE UPGRADE PLEINE PUISSANCE
ENVOIE RAPIDE EN COLISSIMO RECOMMANDER REMISE CONTRE SIGNATURE OBLIGATOIRE
PRIX : 320 EURO
ENVOI : 18 EURO
ARBRE A CAM VHPD 280° LOTUS ROVER MG CATERHAM LAND K-SERIES
